TPMS / Security Lights Battery Drain
Old 09-16-2015 | 07:59 PM
cummins 6.7's Avatar
cummins 6.7
Default TPMS / Security Lights Battery Drain
ok
i just checked the amps on the truck again
i let the truck set for about 10 minutes then i connected the amp meter and i had around 2.90 amps then after about 5 minutes it went down to .09 amps(90 mA)
i pulled fuse m38 -iod-ccn/interior mods
and it began jumping from .09 to .08 then i plugged the fuse back in( i did this 3 or 4 times to be sure) and the amps went up to about 2.90 again then again after 5 minutes back down to .09 and stays steady
what you think??
Old 09-16-2015 | 08:10 PM
Pedro Dog's Avatar
Pedro Dog
90 milliamps seems a little high to me but I'm not familiar with your vehicle model. Like I said earlier, both of my vehicles (2002 c5 vette & 2009 Ram) use up about 20 to 30 milliamps when resting.
Are your batteries going dead? if so, how long does it take. I would think that at 90 milliamps, they should last a couple of weeks.
Old 09-16-2015 | 08:11 PM
cummins 6.7
fui
i just hooked up the other battery to see what it would do and it went down to .03 amps and its staying steady
fyi
yesterday i did fix my hood latch switch, its suppose to let me remote start my truck..... idk if that switch can draw amps or notmif bad
fyi
i did just replace my 3rd brake light with the stock brake light because the recon light i had would stay on; kinda dim but would stay on
Old 09-16-2015 | 08:12 PM
cummins 6.7
they usually die at about 2 days but maybe the switch or the brake light fixed it
hopefully
Old 09-16-2015 | 08:13 PM
cummins 6.7
after bout 10 minutes its goin down still
now its to .02 and .01
Old 09-16-2015 | 08:18 PM
cummins 6.7
now it just hit .01 and staying steady
Old 09-16-2015 | 08:22 PM
Pedro Dog's Avatar
Pedro Dog
if you got it down to .01 or .02 amps, then you should be good. I would charge the batteries up tonight and just watch it over the next few days.
I'm not familiar with the dual battery setup on the cummins but there is probably some kind of isolator to keep the batteries from pulling each other down.
When you have two parallel batteries and one is weaker then the other, it draws current from the stronger one and brings that one down. This keeps going back and forth until they are both bad. That is why you always replace both batteries at the same time.
It's interesting that you said that after you hooked up the other battery, the draw went down. I'm at a loss there.
Old 09-16-2015 | 08:24 PM
cummins 6.7
hey bud
thanks for the help
appreciate it
may god bless you sir!!!!! =]
Old 09-16-2015 | 08:29 PM
Pedro Dog's Avatar
Pedro Dog
good luck and let us know in a few days if you're golden
Old 09-21-2015 | 08:27 PM
Pedro Dog's Avatar
Pedro Dog
any update?
Quick Reply: TPMS / Security Lights Battery Drain
