N 08 Pinion nut recall: From bad to worse...
Old Nov 7, 2013 | 01:12 PM
  #31
capsfloyd's Avatar
capsfloyd
my 09 was in at Dallas Dodge , they replaced the grears also
never told me if mine was lose .... never had a problem
195,000
Old Nov 7, 2013 | 01:16 PM
  #32
capsfloyd's Avatar
capsfloyd
Originally Posted by alex_ac
Do you guys think that if I changed out the gears for bigger ratio would I still be covered under the recall??
i ask that at the dealer going from 321 to 355 , would not do it since it was a safety recall
Old Nov 8, 2013 | 08:07 AM
  #33
DodgeRam09's Avatar
DodgeRam09
I had the recall done. They installed the retainer. They had no clue to the death wobble, vibrations and whining noise. Still have that problem.
Old Nov 9, 2013 | 10:39 PM
  #34
gcburkett's Avatar
gcburkett
Death wobble is generally on for the 2500 and 3500 trucks. If you have steering looseness and vibrations on the 1500 then I would check the suspension parts closely. When do you have the whining noise?
Old Nov 10, 2013 | 07:22 AM
  #35
DodgeRam09's Avatar
DodgeRam09
Above 55 MPH. If I could put it in words it goes wah....wah...wah...wah. Vibration gets worse on wah.
Old Nov 10, 2013 | 11:11 AM
  #36
LU229's Avatar
LU229
How many miles on your truck... sounds like maybe a bad wheel bearing(?)
I would at least jack it up and wiggle the wheels and see if ther is any play.
Whats the tires look like... are they all chopped on the edges... maybe broken belts... tire pressure... ???
Old Nov 11, 2013 | 07:33 AM
  #37
DodgeRam09's Avatar
DodgeRam09
44k but it started around 30k. My original rear tires did wear 'knobby' on the edges. I just had brand new tires put on 1k miles ago. My dad has an 06' and bearings failed at 50k. I'll jack it up and check. All belts and tire pressure good. Just had alignment and balance with new tires.
Old Nov 11, 2013 | 11:23 AM
  #38
capsfloyd's Avatar
capsfloyd
my 09 is 2 wheel drive , had both front hubs replaced ... never had the death wobble , but did vibrate some .. but i noticed the WA WA WA sound first
also you may need to change shocks . My wranglers , did the same ... I rotate every 4-5 000 miles , plus I use BF Goodrich long trails
Good luck
Old Nov 11, 2013 | 12:17 PM
  #39
robinsonfam1's Avatar
robinsonfam1
this is typically a drive line vibration. driveshafts being at wrong angles from transfer case/diff.
is your truck lifted or any changes to suspension from stock?
Old Nov 11, 2013 | 12:30 PM
  #40
robinsonfam1
wheel bearings will make a constant sound...typically don't produce vibrations as described. if wheel bearing you will hear it at slow speeds as well.
please provide all details about your truck model so we can help as best as possible.
