Puddle light
Old Feb 16, 2014 | 07:37 PM
pil03001's Avatar
pil03001
Default Puddle light
Looks like my puddle light on my 2009 dodge ram sport shorted out due to the water issue. I have looked all over for a part number, but it seems like you have to replace the whole mirror is this still true? I am talking about the non-tow mirrors FYI. Thanks
Old Feb 16, 2014 | 08:07 PM
BigBlueEdge's Avatar
BigBlueEdge
The puddle lamp module pops out and is replaceable. It has its own part number (left & right, I think). About $32/ea.
This thread may be of use:
http://www.cumminsforum.com/forum/4t...ng-mirror.html
I know the numbers have been posted here before too.
Rob
Old Feb 16, 2014 | 08:08 PM
BigBlueEdge
Oh, you don't have the towing mirrors. I don't know if the modules are the same on those...
Old Feb 17, 2014 | 08:09 AM
pil03001's Avatar
pil03001
Towing and non-towing mirrors have completely different modules and the numbers I found from 3 different dodge forums are for towing. I think I'm going to replace the LEDs with superbrightleds and see how that works out.
Old Feb 18, 2014 | 11:38 PM
LU229's Avatar
LU229
You didnt say which side... i`ll bet drivers side...??? (drivers side is most used)
Before you go rippin into it, see if you have voltage at the puddle light.
If not, likely a broken wire(s) within the harness going into the door.
If so, tear into it and put some new lights in there.
Old Feb 19, 2014 | 07:43 PM
pil03001's Avatar
pil03001
Passenger side. I already took the unit out and apart and you can tell it was shorted out by water due to the water marks and burnt circuit. Already got a new LED strips that are weather resistant and will be brighter than before. Plus I will be replacing the blinkers as well since I have it apart.
Old Feb 19, 2014 | 11:38 PM
LU229's Avatar
LU229
Well, tear right into`r...! Agreed, replace them turn sig`s too.
Old Mar 13, 2014 | 12:53 PM
klutz02's Avatar
klutz02
I bought one off of Ebay. It was around $89 and that was about as cheap as I could find it anywhere. It has the puddle light/blinker light all in one. It pops off and plugs in. Really simple. Here is an auction that has one.
http://www.ebay.com/itm/09-14-Dodge-Ram-1500-10-13-2500-FRONT-PASSENGER-MIRROR-TURN-SIGNAL-OEM-MOPAR-/201050288632?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ecf87f1f8&vxp=mtr
