Horn sticks on when opening or unlocking door.
Old Feb 24, 2014 | 02:16 PM
lyndon9's Avatar
lyndon9
New Member
Default Horn sticks on when opening or unlocking door.
Any....i mean ANY ideas why my horn sticks on when i unlock my doors? Been to the dealer 8 times now. After replacing win module, horn switch, and tipm, dealer and chrysler havent figured it out. Im looking for any info. That can lead me in the right direction in getting this issue resolved. Plus my neighbors would like me again!...lol... Thanks
Old Feb 24, 2014 | 02:43 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
When the horn sticks, what do you do..pull the fuses? When you put them back in, does the horn keep blowing?
Is it a solid "blow" or is it an alarm trigger?
Fuses M22 and M23 under the hood.
Does it happen with both key fobs? One of them could be sending the panic signal??
Old Feb 24, 2014 | 05:17 PM
Duso02's Avatar
Duso02
I know it needs to be fixed, but in the meantime, you do know that you can disable the horn-blow during lock and unlock?
Old Feb 24, 2014 | 07:25 PM
Pedro Dog's Avatar
Pedro Dog
on my '09 in the EVIC under "setup" you can select or unselect "horn with remote lock"
Old Feb 24, 2014 | 08:03 PM
lyndon9's Avatar
lyndon9
New Member
Here is a more detailed description of my problem. The horn blows steady when i either unlock the door with the key fob or just open the door. It doesnt happen all the time though. Thats whats making it tough to resolve. While in between visits to the dealer, i remove the 2 fuses( my neighbors appriciate that) it has nothing to do with alarm. The panic button works right and alarm work normal also. The one thing i noticed is the horn shuts off when the dome ligjt goes out. Somewhere the wiring for the dome light is tied in with the horn.
Old Feb 24, 2014 | 08:20 PM
WESIDE's Avatar
WESIDE
You got an aftermarket alarm or ignition kill on there?
Old Feb 24, 2014 | 10:13 PM
TNtech's Avatar
TNtech
Originally Posted by lyndon9
The one thing I noticed is the horn shuts off when the dome light goes out.
That's going to be the key right there, because when you hit the unlock button it also triggers the dome lamps to come on. The cluster is the driver for the dome lamps and the steering wheel controls communicate (through the cluster) over the LIN BUS Via the steering control module. I would be looking for signs of wires rubbing/pinching in the steering column or the behind the cluster. The steering control module OR the cluster could also have a temperature sensitive condition on the circuit board.
Yes, like WESIDE said. Do you have ANY aftermarket items installed?
Old Feb 24, 2014 | 10:58 PM
Charlie5280's Avatar
Charlie5280
I agree. Most aftermarket alarms/horns do this type of stuff. They suck!
Old Feb 25, 2014 | 09:35 AM
lyndon9's Avatar
lyndon9
New Member
Its a factory alarm per the window sticker.
Old Feb 25, 2014 | 08:29 PM
WESIDE's Avatar
WESIDE
Next to the headlight swich on my 09 there is a roller wheel whitch adjusts console brightness and also adjusts puddle light and interior lights to turn on or off. I would mess with this and see if you get the dome light to not come on. This will fix ur problem short term if ur alarm is being activated by the dome light circuit.
Good luck
