Old Aug 17, 2015, 01:01 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
What grade for exhaust manifold bolt?
Old Aug 5, 2014 | 11:40 PM
gr8rows's Avatar
gr8rows
Default What grade for exhaust manifold bolt?
I had 2 broken exhaust manifold studs on my 2010 TRX, (right rears) they both broke off flush. I f'd the threads up on 1/4 inch of one of the holes and the dealer stud isn't threaded on the last 1/4". The hole is plenty deep for a longer bolt. So... I need to know what people have tried "grade wise" I have the length figured out. I know its a common problem and I'm a little weary putting a stainless steel bolt, or even a grade 8 or 10.9 I guess they are metric. Just based on the fact that it probably will break again and I will be the one to fix it again. Thanks Dodge. I really don't know what would be best. I replaced all the other bolts, studs, and gasket, just need some help with this 1 bolt. By the way this needs to be a recall. It happened to my dads 2012 at 30,000, and his 2010 powerwagon at 40,000. That's 3 for 3 in the family. Starting to rethink Dodge all together.
Old Aug 6, 2014 | 10:33 PM
gr8rows's Avatar
gr8rows
Never mind. I just put a 10.9 with some anti seize in it. Not embarrassed to drive it now.
Old Sep 2, 2014 | 11:42 AM
gopackgo69's Avatar
gopackgo69
Its a powertrain warranty item. Fixed for free, with the new bolts.
Old Sep 2, 2014 | 12:36 PM
HammerZ71's Avatar
HammerZ71
Been an issue with all Chrysler V8s since Daimler (Mercedes) ownership. Had to do the two rearmost on the driver side of the 4.7 HO in my old Grand Cherokee and did the rearmost one on my Ram.
Luckily, they come right out...
Old Sep 3, 2014 | 11:06 AM
gr8rows's Avatar
gr8rows
Not covered by any warranty around here. I checked with two different dealers
Old Sep 3, 2014 | 11:55 AM
Pedro Dog's Avatar
Pedro Dog
On the '09 original owners, it's covered under the lifetime powertrain warranty, the warranty mentions the exhaust manifold but not the bolts, but it's understood that the bolts are covered - if there is a leak, it's covered.
On the '10, it's covered under the 5 year 100k powertrain warranty, if you are under 5 years and 100 k miles, read the warranty, if it says manifold, then argue with chrysler.
Old Sep 3, 2014 | 12:17 PM
BigBlueEdge's Avatar
BigBlueEdge
Mine was covered by the 100K powertrain warranty and I was over 36K at the time.
Rob
Old Sep 4, 2014 | 10:13 PM
gr8rows's Avatar
gr8rows
My dads 2010 power wagon has the same broken bolts and 40,000 miles on it and they won't fix it to under warranty either. We looked into it together, before I fixed it myself. We took our vins and miles to both dealers and they basically said tough sh*t. They just told me to hang on to my receipt, because I could be reimbursed if it became a recall. The one dealer had 10 manifold gaskets and 50 some odd bolts in stock. He said its a very common problem.
Old Sep 5, 2014 | 12:19 AM
Pedro Dog's Avatar
Pedro Dog
this from the website for a 2010 ram 1500
http://www.ramtrucks.com/shared/pdf/...90109-1500.pdf
this is what it says
2.4 Powertrain Limited Warranty
(EXCLUDES: Sprinter and Ram Chassis Cab)
A. Who Is Covered?
You are covered by the Powertrain Limited
Warranty if you are a purchaser for use of the
vehicle.
B. What's Covered
The Powertrain Limited Warranty covers the
cost of all parts and labor needed to repair a
powertrain component listed in section 2.4.F
below that is defective in workmanship and
materials.
C. How Long It Lasts
The Powertrain Limited Warranty lasts for up to
5 years or 100,000 miles on the odometer, whichever
occurs first, calculated from the start date of the
Basic Limited Warranty, as set forth in Section 2.1(E).
D. Towing Costs Are Covered
The Powertrain Limited Warranty covers the cost of
towing your vehicle to the nearest authorized
Chrysler, Dodge or Jeep dealer if your vehicle
cannot be driven because a covered part has failed.
Gasoline Engine:
cylinder block and all internal
parts; cylinder head assemblies; timing case, timing
chain, timing belt, gears and sprockets; vibration
damper; oil pump; water pump and housing; intake and
exhaust manifolds; flywheel with starter ring gear; core
plugs; valve covers; oil pan; turbocharger housing and
internal parts; turbocharger wastegate actuator;
supercharger; serpentine belt tensioner; seals and
gaskets for listed components only
Old Sep 5, 2014 | 12:27 AM
Pedro Dog's Avatar
Pedro Dog
So given that the truck should be covered for the broken bolts, are you being refused because you tried to fix it first? In that case, you are not covered.
