High Beams No worky
Old Aug 9, 2014 | 12:32 AM
nobby's Avatar
nobby
Default High Beams No worky
2010 Ram Sport with those front air dam fog (?) lights that are activated when you push the head light ****.
I seem to have no high beams.
Fogs off and high beams selected......the blue dash idiot light comes on but no actual high beams.
Same with the fogs on...no high beams.
Is there some relay to look for?
Of course....I'm an idiot....I haven't checked the fuse bank yet.
Let me do that first.
Old Aug 9, 2014 | 01:27 AM
NV290's Avatar
NV290
And once you check that see if you have power at the bulb socket. It is possible you simply have two dead bulbs. It's not unusual for bulbs to die at close to the same time when they were installed new at the same time.
Old Aug 9, 2014 | 06:48 AM
nobby's Avatar
nobby
I guess I could look all day for a fuse and never find one for the head lights.
Apparently controlled by the Totally Intergrated Power Module (TIPM).
Dealer only fix?
Old Aug 9, 2014 | 12:16 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Check for power @
Left high beam= White/Lt Green
Right high Beam= White/Grey
There is also a chance the switch isn't sending a high beam request to the TIPM. You need a scan tool to see that though.
Old Aug 9, 2014 | 08:34 PM
nobby's Avatar
nobby
Originally Posted by TNtech
Check for power @
OK...I'll check that next.
While I have you on the phone......the courtesy light (blue) in the driver's side outside mirror (underneath) is not working either.
Apart from a hammer....how do I pop that lens off without pooching it?
Please forgive me.......I can wrench but this truck is pretty new to me.
Old Aug 16, 2014 | 10:55 PM
nobby's Avatar
nobby
Here's a good write up on the "puddle light" nested in the mirror assembly.
http://www.********.com/f75/how_disa...mirrors-13149/
Old Aug 16, 2014 | 10:57 PM
nobby's Avatar
nobby
That would be ram forum dot com.
