check engine light
Old Aug 17, 2014 | 10:26 PM
BlackWolf's Avatar
BlackWolf
Default check engine light
Hi....I have a 2013 ram 1500, with a 3.6 motor and 8 speed trans. today the check engine light came on. Oil temp is good but the oil kps is 688 and that is high should be only half that, it dont go up or down just stays on 688. Any thoughts as what might be wrong. Everything else is normal. Thanks
Old Aug 18, 2014 | 09:19 AM
NV290's Avatar
NV290
Do you have a local auto parts store chain where they hook up a scanner and read the codes? Their are literally thousands of possible reasons why the CEL is on and it would be impossible to guess.
Old Aug 18, 2014 | 11:06 AM
BlackWolf's Avatar
BlackWolf
I had it to the dealer today,it was a sensor that was gone, it was the sensor that was under the manifold, turned out to be a 3 hour job. All good now thanks.
Old Aug 18, 2014 | 12:16 PM
Buy yourself a code reader. They pay for themselves the first time you use one.
Old Aug 18, 2014 | 02:18 PM
NV290's Avatar
NV290
Considering Auto Zone, Pep Boys, Advance Auto Parts and O'Reilly will read your codes for free it's still cheaper then buying a code reader. If you throw codes all the time for years on end then buying your own scanner would make sense. But in my three Ram's i have owned totaling 12 years and still going i have only had a CEL come on 3 times.
