OEM Auxiliary Switches
Old Sep 28, 2014 | 06:09 PM
rbrumm's Avatar
rbrumm
Default OEM Auxiliary Switches
For those of you who have done this install, was there an existing plug clipped to the blank panel that you removed? I have a 2011 Outdoorsman and found this attached to the blank RAM panel.
Any clues? I hope it is a power source to run power to the switches. Looks like the same plug needed.
Old Sep 29, 2014 | 08:11 PM
rbrumm's Avatar
rbrumm
One thought was it may be for the 110V plug that my truck didn't come with, but I think that switch is in the upper panel. Anyone what would be in the lower panel as an option? another thought was seat heaters, but there are only 3 wires...I assume one 12v, one ground and one accessory.
Anyone...anyone... Bueller?
Old Oct 2, 2014 | 06:08 PM
bigtone's Avatar
bigtone
It is for the switches that get installed there, such as the heated/cooled seats, wheel, etc. Any power there would be only low current, I wouldn't try to power accessory lights off of it.
Old Oct 2, 2014 | 06:40 PM
rbrumm's Avatar
rbrumm
No, I realize that...Wondering if that could be used to power the panel itself (to send the current to a relay). I am not sure if the aux. panel has lights behind the buttons that dim with the dash either. I know that the light above it will light when activated.
Old Oct 2, 2014 | 08:22 PM
Pedro Dog's Avatar
Pedro Dog
Just some friendly advice from an electrical engineer. Even if you figure out the wiring source, you will find out that it most likely comes from the TIPM. Now, the TIPM sometimes uses fused outputs and sometimes it does not. It's really easy to blow a TIPM if you accidentaly short something or even get a voltage spike. Just read the posts from guys that have blown TIPMs messing with their headlights.
I used to design electrical interfaces for fighter jet systems and as trivial as they may seem, we used to spend a lot of time with them. Special receivers to match the drivers, switch de-bouncers, specified capacitance wiring, inductive filtering, etc...
If you want to be safe, run a fused source from the battery to where you need it, should be fairly easy to get a harness to the spot you are looking at.
Old Oct 3, 2014 | 06:11 PM
rbrumm's Avatar
rbrumm
I was thinking about pulling the keyed power from the left 12v aux plug and constant 12v power from the right one. If I fused them before the aux panel do you think that would work. I was going to power any optional equipment with relays with source power from the battery. I assume the 12v plugs are already fused from their source.
Thoughts?
Old Oct 4, 2014 | 11:25 AM
Pedro Dog's Avatar
Pedro Dog
Thoughts?
Those are fused, go here for the wiring diagrams and fuses.
https://techauthorityonlinedemo.extr...ew/classic.htm
Select "power outlets" and look at the wiring diagrams and for the connector details such as location and wiring color scheme select "connectors", it's all there.
Old Oct 5, 2014 | 12:27 PM
rbrumm's Avatar
rbrumm
Thanks!
