2.5 lift, rim and tire combos(no rubbing)?
Old Nov 17, 2014 | 03:21 PM
blairfalconer11@hotmail.com's Avatar
Default 2.5 lift, rim and tire combos(no rubbing)?
Just wondering what combination of tires and aftermarket rims some of you guys have in your 4th gens with no rubbing.
I want to run some 18x9 xd's with 0 offset with 305/65/18 (33.6x12x18). I think it will work with no rub, but not sure from what I've been researching I can't figure out what offset to get to absolutely prevent rubbing.
So in ur posts i want to know ur rim sizes, rim offset and tire size. No rubbing.
Thanks
Old Nov 18, 2014 | 01:02 AM
gr8rows's Avatar
gr8rows
You should be good with 0 offset on a 9" wide rim. So 4.5" backspace. You would need to do the math if you went with a 10" wide rim. I ran xd misfits 20x9 0 offset no rub w/rancho quicklifts.
Old Nov 18, 2014 | 12:45 PM
The tire is going to be about a inch wider. stock is 11 inch's wide.
Old Nov 19, 2014 | 08:28 AM
Whiteout08's Avatar
Whiteout08
For what it's worth, my 2012 had a 2.5" front level and I ran 20x10, -24mm offset wheels with 305/55/20 tires. No rub at all, even without the lift this setup didn't rub...I had these on my 2014 over the summer, no lift, no rub either.
Old Nov 19, 2014 | 10:59 AM
gr8rows's Avatar
gr8rows
Stock rims arent 11 inches wide
Old Nov 19, 2014 | 01:16 PM
Yep I know, was talking about the tire. Im sure this setup will work now. Thanks for all your help
Old Nov 20, 2014 | 11:48 AM
gr8rows's Avatar
gr8rows
I was running 35x12.50 20 Toyo mt's with my level and never rubbed even bouncing across pivot tracks. Just in case you wanted to go bigger.
Old Dec 20, 2014 | 01:14 PM
mrbb1's Avatar
mrbb1
is this a half ton or a 3/4 or 1 ton truck??
on every 2500 I have owned, 33 's fit with room to spare, NOT much,
35's rubbed on every one a LITTLE
in stock mode
so adding any lift will clear 33's with room to spare
ON a half ton, ?? cannot help haven't owned one in yrs!
