Resonator delete pros and cons
Old Apr 25, 2015 | 04:03 PM
98Dodgeram360V8Mag's Avatar
98Dodgeram360V8Mag
Default Resonator delete pros and cons
Hey guys, I was wanting to know if taking the resonators off will harm anything. Currently I have the stock setup but I took out the stock muffler and put a dual in single out Cherry Bomb Extreme on. I have a 5.7 Hemi. It is the factory dual exhaust.
Old Apr 25, 2015 | 10:49 PM
Largefarva's Avatar
Largefarva
So without the factory muffler are you having tons of drone from Mds? The resonators help absorb some noise from Mds but otherwise do very little, removing them won't cause any harm but you also will likely see very little difference in sound or performance.
Old Apr 26, 2015 | 06:59 AM
98Dodgeram360V8Mag
There is like no drone at all.
Old Apr 26, 2015 | 09:21 AM
Best thing I did on the Dakota. It had two resonators, removed them both and put a magnaflow muffler. Sounded awesome.
Old Apr 26, 2015 | 09:52 AM
98Dodgeram360V8Mag
Yeah I love the way my truck sounds now with the Extreme. It has such a deep rumble but when you get into it, it gets up there in the decibels. Lol I don't know, I just thought I would try it to see what it would sound like. It's not like I can't just have them put right back on. Just wanting to know if there was gonna be any negative effects (engine).
Old Apr 26, 2015 | 09:57 AM
No negative effects at all.
Old May 9, 2015 | 07:54 AM
aktrite28's Avatar
aktrite28
Where do you live?
Here in Cali, after a car/truck is 6years old, we are required to do smog inspection. Removal of resonators will cause you to fail smog. And those babies are pricey, so at least dont throw them away!
UOTE=98Dodgeram360V8Mag;3242540]Hey guys, I was wanting to know if taking the resonators off will harm anything. Currently I have the stock setup but I took out the stock muffler and put a dual in single out Cherry Bomb Extreme on. I have a 5.7 Hemi. It is the factory dual exhaust.[/QUOTE]
Old May 9, 2015 | 09:09 PM
NV290's Avatar
NV290
Originally Posted by aktrite28
Where do you live?
A resonator has absolutely nothing to do with with emissions on any vehicle, (other than the fact that the exhaust passes through it). Removal of one or both resonators in our trucks will not have any impact whatsoever on emissions.All they do is alter the sound, nothing more.
Old May 10, 2015 | 08:21 AM
Where do you live?
[/QUOTE]
Wrong. Resonators have nothing to do with emissions.
dwaldmann's Avatar
dwaldmann
Originally Posted by NV290
A resonator has absolutely nothing to do with with emissions on any vehicle.
True. Sort of. It doesn't change pollution emissions, but as you said, it does change sound emission.
Regardless, I know I've heard that some states (probably CA!) don't allow their inspectors to use their noggin. They simply say that all exhaust components must be factory. If you're lucky, you'll get an inspector that doesn't know or care, but if you get a stickler I can almost guarantee that a resonator delete will get you a fail.
