Passenger high beam not working.
Old Oct 26, 2015 | 05:41 PM
Bosox93's Avatar
Bosox93
Default Passenger high beam not working.
So a couple months ago I swapped out my stock headlights for a set of recons. They had been working fine up until a couple weeks ago when my passenger side high beam(uses same bulb for daytime runner) went out. Figured it was just the bulb burnt out. I finally had a chance to check it out yesterday and once I pulled the bulb out, it didn't look burnt. So I pulled the other headlight off and swapped bulbs and still nothing. I put both bulbs in the drivers side and both worked. So I checked for power going to the socket, had 12v but once I plugged the bulb in, I lost the power. Has anyone ever seen this before or have any solutions? Thanks
Old Oct 26, 2015 | 06:50 PM
Pedro Dog's Avatar
Pedro Dog
try the OEM bulbs, if that doesn't fix it, you may need a new TIPM
Old Oct 26, 2015 | 08:09 PM
jasonw's Avatar
jasonw
Site Moderator
Not sure how the quad headlamps work for 100% certain, but try the OEM housing on that side. If the bulb still doesn't work, then it may be something along the lines of what Pedro said.
Old Oct 26, 2015 | 10:49 PM
Bosox93's Avatar
Bosox93
That's worth a shot, what is a TIPM?
Old Oct 27, 2015 | 01:51 AM
CHILLYPOND's Avatar
CHILLYPOND
Totally Integrated Power Module. Think of it as a Power Distribution Center (PDC/fuse box) on steroids.
Old Oct 27, 2015 | 07:34 AM
Bosox93's Avatar
Bosox93
That doesn't sound cheap, anyway of testing it?
Old Oct 27, 2015 | 08:18 AM
biggcrisp's Avatar
biggcrisp
Try cleaning the connector...the one outside of the housing. That solution fixed an intermittent issue with my passenger side low beam.
Old Oct 27, 2015 | 09:07 AM
BigBlueEdge's Avatar
BigBlueEdge
Are these recon lights HIDs? Do they have a ballast? If so, that may have failed. Try swapping ballasts between sides and see if the problem follows the ballast. Rob
Old Oct 27, 2015 | 12:37 PM
Pedro Dog's Avatar
Pedro Dog
The design of this truck for the head lamp drivers is moronic. There are no replaceable fuses that I am aware of. The TIPM drives the bulbs (or ballast for the HIDs) directly from the TIPM circuit board. All it takes is one ah $hit! to blow the TIPM and the replacement is not cheap.
Old Oct 27, 2015 | 12:58 PM
Bosox93's Avatar
Bosox93
I checked the connector at the headlight but totally forgot about that, defiantly gotta check that, thanks
They are not HIDs, just halogens.
