Chain noise while coasting.
Old Jul 12, 2016 | 02:32 PM
DodgeCares's Avatar
DodgeCares
Originally Posted by 11ram
I noticed my 11 ram crewcab is also making the same noise. Have a appointment made for next Tues at dodge dealer but I'm skeptical that they will be able diagnose the problem as they have never heard make that noise they said. And they probably will not listen to my suggestions I'm sure. I read the big thread from the link above and it does sound like a rattling timing chain or in that area. Hopefully the dealer can diagnose it. I'll post a link of video shortly.
Is the noise consistent? Be sure to try and conduct a ride-a-long with the dealer if possible to clearly illuminate your concern. Let me know if you're in need of further assistance once visiting the dealer. - Kevin T, Social Connect Team
Old Jul 20, 2016 | 06:31 AM
11ram's Avatar
11ram
So got the truck back from the dealer yesterday. They fixed it but dnot know which of the 2 things fixed it. They noticed I had a cheap filter and don't know what kind of oil I had in it. So they use wynns engine flush and then did a fresh oil change. Also theres a bulletin out for the mds system for a drone or vibration noise which mine did not really sound like. But going around 40 or 50 km/h I do not hear the noise on the buildings. I'll keep it updated if it comes back or not
Old Jul 21, 2016 | 07:20 AM
Dusty48's Avatar
Dusty48
Default What you are describing is an MDS noise
Guys, Pedro Dog included this link in an earlier post: https://dodgeforum.com/forum/4th-gen-...-coasting.html
I suggest you read all of the entries. A number of people had this issue and a lot of things were changed, but I've become convinced that unless the timing chain and/or chain tensioners are seriously worn, it is probably the Cam Phaser.
Regards,
Dusty
2014 Ram Big Horn 1500 Quad Cab2WD, 5.7 Hemi, 8HP70, 3.92 LSD, factory dual exhaust, 20” wheels. Now at:042173 miles.
Old Oct 26, 2023 | 07:11 PM
Chanpan's Avatar
Chanpan
Default What was it mine is doing it.
Originally Posted by blood_monster2
Hey guys , ive got a 2011 hemi. Basically what happens is if there is no strain on the motor and I have my windows down I can hear a ticking sound very similar to a bicycle coasting without pedaling As soon as I touch the gas it dissapears. Also no tick at idle, And Putting the transmission in the TRS mode and driving in 5th gear, no sound at coast down.
Selecting Tow/Haul mode, no sound at coast down.
Putting the transmission into neutral, the sound disappears.
In normal driving mode the sound disappears at around 1200 RPM regardless of road speed.
The common factor with all four is the MDS. (MDS is off in neutral, Tow/Haul mode, TRS mode, and at or just above idle. I specifically watched the ECO indicator and sure enough when the ECO indicator goes off on coast down, the noise disappears.
some of people say its the timing chain tensioner or the timing belt chain itself and some say its the camshaft, or MDS lifters.
here's a video the the problem exact same problem : https://www.youtube.com/watch?v=LTahQGKNRck
please am hopeless dealerships cant figure it out everytime they tell me somethin.
HELPP!
Dodge ram 1500 2011 5.7L
65.000 miles on it
out of warranty.
What was it? Mine is doing this exactly. 180,000 miles.
Old Oct 26, 2023 | 09:24 PM
blood_monster2's Avatar
blood_monster2
camshaft phaser was worn out along with timing chain tensioner and timing belt chain. Reason lack of oil engine it was burning oil due to bad valve seals without realising.
Old Oct 26, 2023 | 09:51 PM
Chanpan's Avatar
Chanpan
thanks. I'm thinking a new car is in my near future...like Monday!
