dodge trailer code error
Old Aug 30, 2017 | 09:52 PM
Z@kkk033's Avatar
Z@kkk033
Default dodge trailer code error
Getting 56 with flashing trailer and exclamation !. lights dont work, but recognize's the plug. also, red "NO" trailer warning and read out that says Check Trailer brake wiring. any ideals?
Old Aug 31, 2017 | 09:51 AM
What year is your truck? What kind of trailer? Does your trailer have electric brakes?
Old Aug 31, 2017 | 06:10 PM
SHO Rod's Avatar
SHO Rod
Have you checked the trailer brake wiring and confirmed that it is wired correctly? Are you using a 4-wire connector or a 7-wire plug? Are there any adapters in use?
-Rod
Old Sep 1, 2017 | 06:39 AM
coldsteel's Avatar
coldsteel
Be sure to check your grounds; don't rely on the ball to ground the trailer.
Old Sep 1, 2017 | 09:01 AM
rsdata's Avatar
rsdata
I have a 2014 1500 with factory towing...
last May I got a similar trailer error, when not even towing... over the course of a week, the errors migrated to telling my ABS was bad and gave me no cruise control... this happened 4-5 times.
I took to a friendly mechanic who hooked up his computer and told me there were 4 codes stored that indicated an ABS sensor problem, but after looking at all 4 wheels could find nothing. That was 3 months ago and no errors any more after clearing the code...
