Removing Ball Joint Upper Control Arm
Old Sep 13, 2017 | 12:33 AM
JIL_24/7's Avatar
JIL_24/7
Default Removing Ball Joint Upper Control Arm
Hi,
I am doing the ReadyLift 2" level on my 2017 4x4 1500. I made a mistake and punctured the boot on the ball joint after install, so now I have to remove the UCA. I can't for the life of me get the ball joint to release however. I have hit the boss with a hammer repeatedly and nothing. I am beginning to worry I might be damaging the boss/knuckle. Is that possible? Do most of you just hit it with a deadblow? If so what size? So frustrated with myself for doing this.
Old Sep 13, 2017 | 07:55 AM
SHO Rod's Avatar
SHO Rod
If the 2017 is like the 2014, the ball joint is just a tapered seat ball joint. You remove the ball joint retaining nut from the spindle side, then use a ball joint removal tool. The manufacturer recommends the threaded picklefork prying version, but if you're replacing the ball joint anyway, a regular pickle fork may work.
I'm not sure you'll be able to pop it loose by only using a hammer on the spindle with no pressure applied to the joint. That might possibly work if you have a rather powerful air hammer, but the pickle fork approach will likely yield better results.
-Rod
Old Sep 13, 2017 | 08:19 PM
JIL_24/7's Avatar
JIL_24/7
-Rod
I actually got both of the OEM ball joints loose by just using a claw hammer. Like I said I really did something stupid and messed up the ball joint on the replacement once it was already in. It is the new one I am having a real problem releasing. I am going to try a 4 pound deadblow mallet. It is what all of the instructions suggest. I just didn't have a deadblow. I have one on the way. Will update if works
Old Sep 13, 2017 | 09:28 PM
I use a pair of 3 pound single-jacks. (big hammers.) Hold one against one side, and SMACK the other side. Usually two or three hits, and it pops loose.
Old Sep 14, 2017 | 12:30 AM
JIL_24/7's Avatar
JIL_24/7
I have a 2 pound and 4 pound dead blow coming. I will try that and hopefully it will come out quickly. I have scarred the knuckle. Will that have any long term effects?
Old Sep 14, 2017 | 08:13 AM
I don't know if the dead blow hammers will actually work as well as just a chunk of iron.... Try it and see.
Where did you scar the knuckle?
Old Sep 14, 2017 | 10:41 AM
JIL_24/7's Avatar
JIL_24/7
On the outside of the knuckle you can see and feel where it has been struck by the hammer. The metal there is soft. Is it aluminum? I don't think I could have deformed the seat could I? But you can definitely tell I whacked it a few times. Typical where it is smoother and the seam is flattened kind of stuff.
Old Sep 14, 2017 | 10:49 AM
No worries. I don't know what the knuckles are made of on the newer trucks.... so long as nothing broke, you are fine.
