4WD Low Speed Wobble
Old Dec 16, 2017 | 06:48 AM
EricBing's Avatar
EricBing
Default 4WD Low Speed Wobble
Need some direction...2011 4x4 slt leveled, new upr control arms, Lwr ball joints, new Bilsteins set at 2.1, new stub shaft right side..I Have a wobble under acceleration, at low speed, only in 4 wheel drive high, the cv shaft has a lil play in it on right side, and bushings are wore on sway bar links....what could cause wobble, under hard acceleration its worse with traction control on in snow, not as bad with it off...puzzled here....thanks for any feedback...tires arent very good on front either getting replaced tomorrow, alignment is off a tad,could tires cause it, ??
Old Dec 16, 2017 | 10:25 AM
Fix the known issues, (alignment, tires...) and see if the problem is any better/worse.
