Srv 4 wd 2010 1500 Ram
Old Feb 6, 2018 | 08:21 PM
Joey Rudderham's Avatar
Joey Rudderham
Default Srv 4 wd 2010 1500 Ram
Hey guys I’m having an awful time with this Ram I stripped and axle and stub shaft I replaced both parts and new seal from dealer the 4wd work perfect that night . Next day it’s all gone to crap srv light is on and when I try to put it in 4 wd the 4wd light just keeps flashing .. I replaced the motor that engages the front diff as I was getting a code for front axle disconnect c147b along with circuit low c1464 . The system worked fine for about and hour and as I was driving along the road in two wheel drive as normal the srv 4 wd light came on again . 4 wd will sometimes work now it’s hit or miss but I’m baffled now as to why it’s like this ... those are the only two codes I am currently getting
Old Feb 25, 2021 | 12:29 PM
Cuzimada's Avatar
Cuzimada
Joey, did you ever figure out what was wrong. I have the same error codes and I already replaced the actuator. I've seen some videos saying it's a short. Thanks
Old Feb 23, 2022 | 10:53 AM
bart_r6's Avatar
bart_r6
did any of you guys figure it out? Did you find the short?
Thanks,
Bart
Old Aug 14, 2022 | 12:39 PM
Cuzimada's Avatar
Cuzimada
Thanks,
Bart
Sorry, no still haven't. Going to keep trying to figure it out, and I'll provide an update once I do. It ticks me off when people come on boards looking for help but never report back.
Old Aug 17, 2022 | 07:33 PM
Chuck949910's Avatar
Chuck949910
Mine did the same thing, had to replace the Forward Control Module also, in addition to the shift actuator on the t-case. The dealer has to program the new FCM, takes about an hour.
Chuck
Old Aug 18, 2022 | 07:32 AM
Chuck
They CHARGE you an hour, but, it probably only takes about ten minutes.
