Headlight swapping
Old Mar 30, 2018 | 07:12 PM
Mic g's Avatar
Mic g
Default Headlight swapping
Without pulling out headlight to check, can you replace dual (high/low same bulb) with quad headlights without any other problems. I've got 2012 tradesman and want to upgrade to better better lights. Any one know
Old Mar 30, 2018 | 07:43 PM
Not without replacing the housings. You can’t magically make single bulb housing into dual bulb housings.
Old Mar 30, 2018 | 07:47 PM
Mic g's Avatar
Mic g
That's what I meant. Found deal on headlight. I know whole head light bucket will fit but don't know if wiring/ plugs are different
Old Mar 31, 2018 | 11:21 AM
Yes, the wiring is going to be different. Instead of one bulb socket, you will have two, on each side. There may be adapter harnesses available.... or, you may be able to put your own together.
