2013 Ram 1500 2WD - Ball Joints
Old Apr 5, 2018 | 09:24 PM
Bighauss26's Avatar
Bighauss26
Default 2013 Ram 1500 2WD - Ball Joints
New member here, after changing my brakes with a buddy last weekend I noticed a cracked upper ball joint boot. How hard is it to replace ball joints ? Do i need to replace the entire upper control arm just to replace the ball joint? If i change then myself will i need to put a jack under the calipers to support them from falling ? The truck only has 70k miles on it. Do i even need to replace the ball joint if the boot alone is cracked and there is no play?
thank you.
Old Apr 6, 2018 | 08:17 AM
If there isn't any play, don't need to replace it. The cracked boot will accelerate wear though.... so, it will have to be done at some point.
Old Apr 6, 2018 | 10:20 AM
Bighauss26's Avatar
Bighauss26
Think itll hold up through a 1000 mile road trip lol?
Old Apr 7, 2018 | 08:46 AM
Shouldn't be a problem.
