Weak Ac problem, condenser fan not spinning
Old Jun 21, 2018 | 11:57 PM
Dragoneclipse's Avatar
Dragoneclipse
Ok sounds good. Checked for dtc and I didn’t have any faults. Is the electric fan supposed to kick on as soon as I start the truck with ac on?
sometimes ac blows warm till I turn ac off then back on again. It like it doesn’t like being started with ac left on.
Old Jun 23, 2018 | 12:12 AM
primem's Avatar
primem
without the fan operating and no air flow the high side pressure will go high enough for the high side pressure cut out to shut off the compressor...the system restarts when the pressure drops.
with no fan...the sysem works ok when at highway speeds but blow warm air when your not moving.
Old Jun 23, 2018 | 12:47 AM
Dragoneclipse
Ah hah that makes a lot of sense. So now I just need to figure out what controls fan operation. Should I start by replacing relays?
Old Jun 23, 2018 | 12:48 AM
Dragoneclipse
I’ll be checking that high speed relay that was mentioned as soon as I can.
Old Jun 26, 2018 | 01:58 PM
Dragoneclipse
Solved:
ok ok swapped the high and low speed relays and now the fan kicks on at idle. I’ve ordered a new relay to replace the now inop low speed relay. Thanks guys!
