New Problem ( Fuel pump keeps running with the key out )
I did my mod last week works great! did you look at the link i posted? instructions are fairly clear. One correction.. on my 2011 ram the pink with green wire in figure 17 is just pink . no green stripe/tracer.
I included generic relay pinout numbers on the side of the pics for clarity
I ran across this You Tube video while looking for and answer. The tech has excellent detail on how to install a work around for this issue.
https://www.youtube.com/watch?v=PbOae77t-wU&t=1123s
https://www.verticalvisions.com/prod...ss-cables.html
Thanks for the reply, I actually used another work around, using a jumper wire.
https://www.youtube.com/watch?v=HcV5oAF1hM0
As an additional step I also logged a complaint with the NHTSA. I read hundreds of owners where they were having the same issues. But when I checked to see if a complaint was logged I didn't see any. I would encourage everyone who has this issues to log a complaint as well. This should get the NHTSA to at least open a case and review the issue. With any luck they'll require the manufacture to issue a recall and we can get them to fix all of our trucks.
While the work around you used will get your truck running it does have a major drawback. The fuel fuel pump runs constantly when the key is in the on position. Using the remotely mount relay allows the computer to control the fuel pump. Which is the reason I went with the remote relay work around. There is a draw back with remote relay is that you can't purchase the part number shown in the video. I had to assemble the parts individually, but it works great.
Yes this is another work around. During my initial research this is one of the sites that provided information I used to choose which work around to use. The Vertical Visions solution does provide more control of the fuel pump in the traditional sense, were the circuit board receives an engine running input. It was the only one that I considered to be a viable work around. Looking at the wiring diagram on their web site for the system with testing capabilities, it doesn't appear to isolate the stock relay. The main reason I used the remote relay was to have it controlled by the vehicle PCM, this seemed like the best choice. Using the remote relay setup allows for easy access to the relay if it were to fail and the cost of a replacement relay is about the cost of a six pack.
The Vertical Visions does provide a nice testing system for fuel pump with a disabling function, possibly to use as a security system. Installation is extremely quick and provides circuit protection. It is a much better choice then the bypass wire setup, which I found chilling.
