Loud Buzz or Whine coming from Dash on 2016 Ram 1500
Old Nov 12, 2018 | 03:20 PM
growe41's Avatar
growe41
Unhappy Loud Buzz or Whine coming from Dash on 2016 Ram 1500
I have a Loud High Pitched Whine or Buzz coming from 2016 Ram 1500 Dash - Its so loud it drowns out the radio and hurts your ears.
  • Issue occurs Randomly
    • Doesn't occur every time I drive truck
    • It could last for 1 sec or go continuously until truck is shut off
    • Has done it at least 8 times since I bought truck 2 weeks ago
      • Once it lasted about 2 min
        • This occurrence all I did was unlock the truck and open the door to get in.
        • Truck was not running and key was not in ignition
      • Twice now while driving I have had to pull truck over turn it off and open the door so the dash electronics turn off.
      • The remainder of the times it has only lasted for 1 – 5 sec
The sound itself seems to be originating from lower right side of center dash but its so loud it is hard to tell. Maybe it just sounds like it is coming from bottom as there is an opening in back to the storage area in the console.
I have it into the shop now but everyone I showed video to looked like deer caught in headlights.
I captured a video and posted on Youtube (
Any input would be greatly appreciated
Thanks
​​​​​​​Gary
Old Nov 12, 2018 | 05:11 PM
sottis's Avatar
sottis
Holy crap is that annoying! I would have taken a hatchet to my dash by now. Believe it or not, it could be the hard drive in the radio.
Old Nov 12, 2018 | 05:33 PM
growe41's Avatar
growe41
Yeah scares the crap out of me every time. Like someone sneaking up behind you blowing an air horn..
Old Nov 12, 2018 | 06:07 PM
TrueDogman's Avatar
TrueDogman
First I would try to narrow it down by crawling underneath the dash. Maybe remove some trim and accesories and drive like that. Next I think I would get familiar with fuses and relays. Next time it occurs pull over and start pulling them to isolate the issue a little .
Old Nov 14, 2018 | 11:45 AM
growe41's Avatar
growe41
UPDATE:
I got my Ram back from dealer today, they said they found a failing speaker in the dash. Speaker and speaker bracket were replaced.
Hoping the speaker was issue....
Old Nov 15, 2018 | 03:21 PM
sottis's Avatar
sottis
How could it be a speaker if:
Old Nov 15, 2018 | 04:19 PM
growe41's Avatar
growe41
I don't know what gets power when the doors are unlocked and opened... I do believe it is possible speaker as it was so loud it would give you a headache in minutes.
I'm crossing my fingers - will drive for a week and see what happens... it was random but pretty regular so time will tell...
I'll drop in an update in a week or 2
Old Nov 15, 2018 | 07:30 PM
SHO Rod's Avatar
SHO Rod
Since that is at between 495 and 516 Hz, a speaker issue makes sense. That frequency is too odd to be something like a relay or solenoid that is DC powered. It wouldn't surprise me if that dash speaker is used for things like the headlight chime, door ajar chime, and navigation announcements, so the speaker having power even with the key off doesn't seem improbable either.
I hope for your sake the dealer was correct and the speaker and bracket fixes the issue.
-Rod
Old Nov 16, 2018 | 05:22 PM
DodgeCares's Avatar
DodgeCares
I captured a video and posted on Youtube ( https://youtu.be/eXFSYPvogzs )
Thanks
Gary
UPDATE:
Hi Gary,
Please let us know if this concern returns. Just send us a private message and we will gladly get a case started for you in order to help find a potential solution to this.
Lydia
Dodge Social Care Specialist
