2009 Ram 1500 Laramie Key remote issue
Old Dec 16, 2018 | 06:49 AM
Lewis94's Avatar
Lewis94
Default 2009 Ram 1500 Laramie Key remote issue
Got a a Ram key that won’t lock or unlock, any clue on how to reprogram it? Trying to avoid going to the dealership.
Old Dec 16, 2018 | 08:16 AM
If it’s just a regular key and you are trying to lock/unlock using the keyhole in the door, sounds like it was not cut correctly.
Old Dec 16, 2018 | 08:20 AM
Lewis94's Avatar
Lewis94
The physical key works, it’s the only way I can get in and out locking my truck.. electronically it’s not programmed or something cause I can’t lock it while I’m walking away with my clicker
Old Dec 16, 2018 | 08:27 AM
You need two working keys/FOB’s to program another. If you dont have that, you will need a dealer or locksmith to program it.
Old Dec 16, 2018 | 08:49 AM
outlawstorm's Avatar
outlawstorm
Does the truck have factory remote start? If so can you start the truck with it? Are the batteries fresh inside the remote?
Old Dec 16, 2018 | 09:20 AM
Lewis94's Avatar
Lewis94
batteries are fresh inside the remote, I even cleaned the buttons inside because I seen it was a common issue for dirt and lint to cause issues
Old Dec 16, 2018 | 09:16 PM
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
As stated before you need two remotes to program it. If you don't have that, you have to go to a dealer, locksmith, or a shop that can program your key to the computer.
Old Dec 16, 2018 | 10:50 PM
primem's Avatar
primem
you will need a security pin number to program it...not sure if anyone but the dealer can access the pin.
