What should I look out for in my new RAM 1500
Old Feb 4, 2019 | 07:01 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Originally Posted by primem
the led bulb was orientated correctly and was still NFG?
yes the bulbs are keyed for the single bulb system, you physically cannot install them wrong. now my RAM has a 2 bulb system so im thinking about trying them again, but id have to buy 4 bulbs to try it out properly . . . . havne convinced myself its worth it yet, not after the las fiasco
Old Feb 4, 2019 | 07:46 AM
ZEN357's Avatar
ZEN357
Had a 2012, never experienced the broken manifold bolts, but the headlight wiring harness had to be replaced in one headlight and the wheel bearings went at 120,000 from highway driving. Bearing replacement from a local shop (Not a Stealership) was gonna run $1000. I traded the truck on a Challenger since I had another vehicle to use as my daily driver.
Old Feb 6, 2019 | 04:01 PM
capsfloyd's Avatar
capsfloyd
57,000 miles , should not have really any problems till around 225, 000 miles
1 exhaust bolts
2 fuel pump
3 water pump
that was in the order of mine on a 2009 hemi , now with 409,840 on the clock ... all original engine , transmission, rear axle [recall 2x]
Old Feb 6, 2019 | 04:29 PM
1 exhaust bolts
2 fuel pump
3 water pump
How many times have you had the exhaust bolts done? And do you still have stock manifolds??
Old Feb 7, 2019 | 02:05 PM
primem's Avatar
primem
the led bulbs I've installed were keyed to the lens housing but had set screws so you could rotate the bulb. if it wasn't orientated the correct way...light output from the projection lens was poor.
Old Feb 10, 2019 | 03:01 PM
capsfloyd's Avatar
capsfloyd
2xs more now on my 2009 the mileage is 410,000 on the clock
the MDS went out around 325,000 they replaced the MDS and while in here replaced the cam and lifters under warranty
Old Feb 10, 2019 | 05:15 PM
cjames1173's Avatar
cjames1173
I put in 2 Lasfit 72W LED headlights with anti-flicker drivers. I had a bad connector on the driver side so I cut it off and hardwired to the driver which had a h13 connector on the other end. I elec trical taped all my remaining connectors to avoid further breakage. The light output is unbelievable! Amazon and walmart have them at good prices, under $60 for the lights. Rated at over 3x the lumens and 30,000hr runtime I call em a steal!
Old Feb 11, 2019 | 06:23 AM
shrpshtr325
THE ULTI-MOD
the cutoff was oriented correctly on the ones i had (i dont recall them being adjustable either, but that could be me) so its not like they were installed wrong, the his were awesome, but the lows terrible, do what you need to do just sharing how it went for me.
