2009 1500 Blown Head Gasket
Old Feb 17, 2019 | 10:35 PM
stryker24's Avatar
stryker24
Default 2009 1500 Blown Head Gasket
I have a 2009 1500 SLT. It has 265,000 miles and has started to run extremely rough (like can't even drive down the road rough). When I lift the hood or just stand around the front of the truck, it reeks of coolant. There is no visible leaks of coolant. I drained the oil looking to see if there was coolant in the drain pan, but nothing.
I guess my question is can there be a blown head gasket and no coolant in the oil? There is no coolant smell inside the truck when the heater is on so I don't suspect the heater core is leaking and the heater works fine.
Thanks in advance for the advice!
Severin
Old Feb 18, 2019 | 08:24 AM
Yup. Engine may just be burning the coolant. Are you losing coolant? Engine overheating? Compression test may not be a bad idea.
Old Feb 18, 2019 | 10:27 AM
Mike Sal's Avatar
Mike Sal
If you smell coolant, then it's escaping somewhere.....either on the ground or thru the tail pipe or out the water pump weep hole (this is assuming all hoses are good).
Mike Sal
Old Feb 18, 2019 | 01:45 PM
stryker24's Avatar
stryker24
Yeah at this point there is no coolant leak. I will check the level of the coolant today. The engine has not overheated since the smell has been so strong or running extremely rough.
Any recommendations on exhaust manifolds? I will have to replace the head gaskets and at the same time I have the remove the cracked exhaust manifolds. So does anyone recommend a good replacement?
Thanks in advance!
Severin
Old Feb 18, 2019 | 02:06 PM
Find a good set of shorty headers to install. That eliminates the problem of the exhaust bolts breaking.
Old Feb 18, 2019 | 08:35 PM
Pedro Dog's Avatar
Pedro Dog
most reputable shops have a machine that can test for blown head gaskets by checking contamination with the coolant. I have never used one but there are also kits you can by on amazon.
Old Feb 18, 2019 | 09:12 PM
Good Idea. I know the parts stores around here will rent you the kit, just pay for the chems. (which they also have.)
Old Feb 18, 2019 | 11:42 PM
stryker24's Avatar
stryker24
Thanks All for the help!
Severin
Old Feb 19, 2019 | 08:09 AM
ZEN357's Avatar
ZEN357
Yes, It does sound like a blown head gasket. Could be a slow leak that is getting burnt up. Good Luck.
