Frisbee sound 2012 Ram 1500
Old Apr 15, 2019 | 08:46 AM
MrQ's Avatar
MrQ
Default Frisbee sound 2012 Ram 1500
This is a loud annoying noise that sounds like someone is rubbing sandpaper on metal whenever I drive. I first thought it was the axle, Replaced, no good. Then wheel bearing, replaced, still no good. Even brakes, replaced, still no good. This sound is most noticeable at low speeds and it's loud enough that I have to turn the radio up to not hear it. It is incredibly annoying and the most bothersome thing on my awesome Dodge. Any ideas?
Old Apr 15, 2019 | 08:47 AM
Is it coming from the front? Back? Engine? Interior?
Old Apr 15, 2019 | 08:50 AM
MrQ's Avatar
MrQ
It's hard to tell, I have had it up in the air with it in gear and it seems to be towards the middle of the vehicle.
Old Apr 15, 2019 | 09:35 AM
Something is rubbing...... If its external, there should be obvious signs, rub marks, etc. If its internal to something, gonna be more fun to find. I once had a weird noise on a truck I had worked on, and it turned out to be one of the brake dust shields was rubbing on the rotor.....
Old Apr 15, 2019 | 03:09 PM
SHO Rod's Avatar
SHO Rod
Your description sounds pretty consistent with a belt driven pulley with a bad bearing. Such a noise would change frequency with engine speed. The water pump, if you have the 5.7L engine, is a rather common culprit. I just replaced one 3 weeks ago on a 2014 5.7L Durango R/T with only 42k miles on it.
-Rod
Old Apr 16, 2019 | 09:04 AM
MrQ's Avatar
MrQ
Huh, never would have thought of that. I'll check it out. Thanks!
Old Apr 16, 2019 | 10:40 AM
MrQ's Avatar
MrQ
I just remembered it varies with the speed of the driveline not the motor, so it's probably not a pulley.
