Chip a 2017 Dodge Ram 3500
I’m thinking about chipping my truck. If I do so how do I delete the emissions? Also what software interface do I need to use? Will I need my 4 digit pin?
thanks in advance.
Jeff
thanks in advance.
Jeff
Yes I’m going to delete the emissions reprogram the PCM/BCM and add a tuner looking at an EZY Link or something along that line.
Just make sure it has the capability to WRITE to the PCM..... Generally, the stuff that allows you to read, edit, write, is rather expensive.
Especially for the newer stuff. Fair few folks offer custom tuning, I don't know what the average handheld will allow you to customize these days though.
and be ok with losing you powertrain warranty or service contract warranty. if you come in with a blown headgasket, engine or trans they will check to see how many times the pcm has been flashed. Even if its all returned to stock; If it has more flashes than what has been done for warranty work...they will know you chipped it and deny warranty.
