DTC Codes
Old Feb 22, 2020 | 07:41 PM
Tommyboi70's Avatar
Tommyboi70
Default DTC Codes
OK everyone, here's my issue lol
2016 Ram hemi I changed my tire size so now my speedo was off. I found how to get into the BCM to change the tire setting. I am using a Matco MaxMe tool. During this, I noticed the check engine light on. I checked the codes and cleared them and the light went off. I started the truck and the light was back on again. I checked the code, P1614-00 ECM reset. I went back into the ECM, TCM and BCM. The code is coming from the TCM but I cannot find any info about it. It is a permanent code. So now every time I start the truck the light is on. How do I get this code deleted? All of my research is coming up nil. I really don't understand why this happened in the first place. The tire size adjustment is done in the BCM. I hope you guys can help me out. Thanx!!!
Old Feb 24, 2020 | 12:11 AM
Tommyboi70's Avatar
Tommyboi70
Anyone out there?
Old Feb 24, 2020 | 08:43 AM
Have a look here. That's an immobilizer code...... why you are getting it is a really good question. If the truck starts, runs, and drives..... something is definitely awry.
Another site seems to think its an ECU reset/recovery, whatever that means...... Wouldn't it be nice if codes were consistent across all manufacturers? Might wanna start looking for a service manual for your truck. Either that, or take it in to the dealer, and see what they have to say.
Old Feb 24, 2020 | 04:21 PM
Tommyboi70's Avatar
Tommyboi70
yeah I keep seeing the immobilizer thing. But my Matco tool says otherwise so I really don't know
Old Feb 24, 2020 | 07:24 PM
What is your tool telling you?
Old Feb 24, 2020 | 09:27 PM
Tommyboi70's Avatar
Tommyboi70
Old Feb 24, 2020 | 09:54 PM
Ok..... Well, we know what the code is, according to theory, your tool should be able to tell you which module initiated the reset..... How you fix that, I really don't have any idea, and there is precious little information on the web for it....... Nothing useful that I could find.
Old Feb 25, 2020 | 12:34 AM
Tommyboi70's Avatar
Tommyboi70
Right... That's the problem that I'm at. It's coming from the TCM, that much I do know
Old Feb 25, 2020 | 08:41 AM
Trans control module?
It would be nice if it would also tells us WHY that module wants a reset........
All this started after updating the PCM for larger tires??? Wonder if there is another step in there somewhere that needs to happen as well.
Old Feb 26, 2020 | 10:08 PM
Tommyboi70's Avatar
Tommyboi70
Not sure. This was the first time I was in the computer. I may have been in the reset tab. Don't know lol
