Ram 1500 2011 High Beam
Old Apr 26, 2020 | 04:14 PM
Gabriel Blanchet's Avatar
Gabriel Blanchet
Default Ram 1500 2011 High Beam
Hi guys i have problem with my driver side high beam not working the passenger side is working just fine and i have 3.5v on the high beam pin on the drive side but never 12v wondering if you guys have any leads as to where i could look next
Old Apr 27, 2020 | 01:46 AM
master tech's Avatar
master tech
Site Moderator & Tech
Have you looked at the headlamp connection? You could have either a bad ground or the pin is pushed out.
Old Apr 27, 2020 | 12:26 PM
Gabriel Blanchet
If the ground was bad the low beams wouldn't work, would you advise changing the female connector ?
Old Apr 27, 2020 | 06:12 PM
TrueDogman's Avatar
TrueDogman
If you have full voltage on passenger side and low voltage on drivers side I think I would start tracing the bad side back to see where your getting the voltage drop.
Old Apr 27, 2020 | 06:35 PM
Gabriel Blanchet
Anyone got the diagram in that case so i can know where to look?
Old Apr 28, 2020 | 12:13 AM
TrueDogman's Avatar
TrueDogman
Try to keep it simple to start. Look at wire colour and tracer colour and see if you can follow it back towards fuse block and ipm. Haven't looked at my 2012 in a while. Is there a separate fuse and or relay for each headlight ??
Old Apr 28, 2020 | 12:21 AM
Gabriel Blanchet
Old Apr 28, 2020 | 12:22 AM
Gabriel Blanchet
m15,m22,m23 might be it but i don't know.
Old Apr 28, 2020 | 02:01 AM
master tech
The fuses is a good start. Are you using a test light, power probe or a DVOM to test for voltage?
Old Apr 28, 2020 | 02:18 AM
Gabriel Blanchet
I'm using a multimeter, do you know the fuse number i should be checking because the way it's identified in the tipm is confusing me.
