2011 3500 Spongy Brakes
Old May 30, 2021 | 04:39 PM
Fadotubby60b's Avatar
Fadotubby60b
Default 2011 3500 Spongy Brakes
2011, 3500 Dually has very soft brakes. 67,000 Miles. Rear caliper pins lubricated, Have to push pedal almost all of the way down. Any thoughts?
Old May 30, 2021 | 07:25 PM
Pads worn out? Leak in the system? Gas or diesel?
Old May 30, 2021 | 07:52 PM
Fadotubby60b
Diesel, pads are good. We are going to take front apart and check caliper bushings on there as well.
Old May 31, 2021 | 10:45 AM
Mike Holmen's Avatar
Mike Holmen
When was the last time you did a brake fluid flush? I would check all the lines for leaks if your losing fluid, you could have some air in the brake lines. Are the caliper sticking and not retracting?
Old Jun 3, 2021 | 01:03 PM
DodgeCares's Avatar
DodgeCares
Hi Fadotubby60b,
We certainly understand why this may be concerning. We kindly recommend having your dealer inspect this concern for you as they are in the best position to assist.
Rob
Dodge Cares
