Would really be a life saver!! #2
Old Jul 8, 2021 | 12:57 PM
Laramielonghorncummins12's Avatar
Default Would really be a life saver!! #2
2012 Ram 2500 Laramie longhorn 6.7 cummins. I have an ignition that won't recognize key because I have changed everything. Ignition did work properly with a bypass module (drone compustart). I know truck was Canadian. I have removed the bypass as my tipm and win module are new. Old key. Anyway, I need to know where the wireless antenna receiver is located, I broke that cable..lol. also another option is wire bypass and I found the wires but not sure which to apply power or ground???. It's been a long while. I have also replaced transmission per bad diagnoses at the dealer. Thanks guys
location of actual wireless receiver?? Please... 2012 long horn Laramie diesel. 6.7. Thanks guys. If I repair wire at the receiver, I can program keys
Old Jul 11, 2021 | 02:08 AM
master tech's Avatar
master tech
Site Moderator & Tech
You need to have the old key re-program as per the vin number on the truck. Or you may need a new key. The win module also need to be program as well as the Tipm module.
