Front and rear differential fluid
Old Jan 5, 2022 | 03:45 PM
Joelmichelle#1's Avatar
Joelmichelle#1
Default Front and rear differential fluid
2016 ram 1500 express 3.6 not sure what fluid to use and if I have to do the limited slip additive In the rear any help would be great thanks in advance.
Old Jan 5, 2022 | 09:09 PM
master tech's Avatar
master tech
Site Moderator & Tech
I would use 75/140 for both.
Old Jan 5, 2022 | 09:37 PM
Joelmichelle#1
Thanks for the quick response I read 75 90 for front what's the difference between 75 90 and 75 140? will it ruin the differential if I use 75 90?
Old Jan 5, 2022 | 09:44 PM
I think they call for the 75/140 for 'heavy duty' applications, if you tow/haul a lot. The 75/90, or 80/90 will keep your gears happy for the foreseeable future.
Get a build sheet for your truck, and see if the LSD is listed, if it is, you need the friction modifier.
