Misfire on Cylinder 6 po306
Old Sep 20, 2022 | 09:19 PM
DirtHauler94's Avatar
DirtHauler94
Default Misfire on Cylinder 6 po306
I have replaced spark plugs and injector. Determind its not the coil. And still getting the po306. What can it be?
Old Sep 21, 2022 | 08:04 AM
What engine?
Old Sep 21, 2022 | 09:48 AM
DirtHauler94
What engine?
5.7 hemi
Old Sep 21, 2022 | 03:05 PM
Dropped valve seat, rounded off cam lobe, pcm not firing the injector or coil, etc.
Hear any odd noises at idle?
Old Sep 21, 2022 | 03:06 PM
DirtHauler94
No just low rpm
Old Sep 21, 2022 | 03:07 PM
DirtHauler94
Rough idle cause rpm too low at 600
Does it misfire at cold startup? Or only once the engine is warmed up a bit?
Old Sep 21, 2022 | 03:11 PM
DirtHauler94
I don't feel it but light on while warming and at idle. It will accel fine and no noise or tells of hemi tick
Old Sep 21, 2022 | 03:18 PM
Have you tested the coil/injector connectors with a noid light? (verifies that the PCM is actually trying to control them.) Tried swapping injectors/coils, to see if the miss moves with either one? What plugs did you put in? And are they the manufacturer recommended plugs?? ( know the older motors have real issues with the rare-earth fellers.... not sure if the newer hemis have the same issue...... 16 plugs, right?
Old Sep 21, 2022 | 03:21 PM
DirtHauler94
I have swapped coils and all coils work fine. I haven't tested the wires to injectors though. What tool was it needed to do that again?
