2012 Dodge RAM 2500 5.7l 4x4 - Front Leveling Kits suggestions?
Good Afternoon;
I would like to level out a 2012 dodge ram 2500 Crew Cab (6ft bed) 5.7l 4x4 - I do not need the best or most expensive leveling kit. I would like to get a front leveling kit to lift between 2-3" total. (level or a bit higher than level in front would work).
Also... I do Not want anything that is considered Soft Ride. I prefer the old school front leaf spring Stiff Ride myself (I do know this one has Coil Springs in front).
I have looked at just pucks and then on up from there. I would really appreciate any/all experienced suggestions. (best for the money spent plus dependability)
Thank You
Thank You
Go for the metal spring spacers, or just replace the springs. Rumor has it, diesel springs will get you in the neighborhood of two inches, but, the ride will be pretty stiff with just the V-8 in front. Several companies make replacement springs for your truck. Should be able to find something you like.
