Hard start after sitting for a couple hours
Old Dec 4, 2022 | 04:21 PM
Niakon's Avatar
Niakon
Default Hard start after sitting for a couple hours
2014 ram 1500 3.6l
Truck has to crank hard after it sits for about 2-4 hours, but if it sits overnight it starts fine. Pretty sure gas is draining back out of the fuel line. Just changed my fuel pump out(had a bad ethanol sensor) thinking the check valve in it was shot. Had this same problem before I changed the pump out. Was hoping that would fix both issues. Only thing I can thing to change is my fuel injector pressure sensor, or vapour sensor maybe cause a vacuum in the tank. Any help would be appreciated thanks.
edit I have already changed out fuel injectors
Old Dec 4, 2022 | 07:47 PM
Is it hard to roll the motor over? Or long crank time when heat soaked?
Old Dec 4, 2022 | 08:02 PM
Niakon's Avatar
Niakon
Long crank time and sputters during start up, while the engine is still warm. Sound and feels like there is no fuel in the line. But once it starts it run just fine.
Was doing some research on fuel vaporization. Then realized that about a year ago I changed out the oil cooler and left the foam piece out that goes between the upper and lower intake. I am now wondering if that also keeps the heat from cooking the fuel line near the engine.
Old Dec 4, 2022 | 08:23 PM
Fuel vaporization is a lot less of an issue on a fuel injected engine. Fuel pressure is somewhere in the neighborhood of 50 to 50 PSI, so, any air in the system gets purged right quick. If it were a check valve problem, you would certainly see the issue after the truck sat overnight..... Try cycling the key twice (not starting on the first try) and see if that doesn't improve anything at all. If the issue persists, it probably isn't a fuel system issue. More likely a sensor that is mis-reading.
Old Dec 4, 2022 | 09:17 PM
Niakon's Avatar
Niakon
Thanks for the info I am leaning more toward the fuel injector pressure sensor. Will probably change that one out and see.
Old Jun 26, 2024 | 03:00 PM
jus43438's Avatar
jus43438
Did you ever get it sorted?? I'm having similar issues!
Old Jun 27, 2024 | 09:06 AM
Niakon's Avatar
Niakon
No I never did get it sorted. We have just learned to live with it for now. One thing I did notice was that when it is hard cranking the butterfly valve in the throttle body slams totally shut. Tried the throttle relearn sequence with the key and that didn’t do anything. Will need to get a computer hooked up and do a proper relearn to see if that works. Otherwise have not really figured anything else out.
