1500 Brake Setup for Towing
Just bought our first tow trailer and they set us up with a wireless brake controller. Absolutely horrible! I heard people complain about them but first time driving it the brakes completely locked up on trailer every time I applied brake pedal. I did all of the correct troubleshooting (adjust pressure, sensitivity etc)
Anyway - how can I find out if my Dodge Ram has a brake setup for towing? I do have both the 3 pin and 7 pin connections on rear of truck
Truck is a 2019 1500 5.3l Hemi V8 Big Horn
Theoretically, you should be able to turn down the brake controller to the point the trailer brakes don't do anything at all.....
Look for the connector under the dash. Dodge had a habit of not varying their wiring harnesses much, and even though you may not have some option or other, you still had the wiring for it. But, even on the trucks that you KNOW it is there, it can be fun to find. Might be tucked up and taped to some other section of the harness under the dash there. It *should* be on the drivers side at least.
