DTC 2097 Post catalyst fuel trim
Old Mar 29, 2023 | 03:08 PM
damdodge##3's Avatar
damdodge##3
Default DTC 2097 Post catalyst fuel trim
Hey folks! I own a 2010 Dodge Ram 1500 - 4.7litre 4x4 and have had very little problems with it up to now. Recently my check engine light has been coming on, when I pulled the code it read - P-2097 - catalyst fuel trim - system too rich bank 1. Any ideas of where I go now?
Old Mar 29, 2023 | 07:12 PM
Check the wiring to the sensor first, make sure the connection is clean and tight. Clear the code. If it comes back, replace the sensor. Do you use Bosch sensors... NTK or Denso.
Old Mar 30, 2023 | 08:09 AM
damdodge##3
Red face P - 2097
Thanks for the tip! I will check the wiring today. May be the problem as I just replaced the exhaust manifold the other day and had the oxygen sensor disconnected.
Old Mar 30, 2023 | 09:30 AM
That should have been: "Do NOT use Bosch Sensors......" Darn keyboard.
