2002-2012 3.7 differences?
Old Aug 17, 2023 | 04:35 PM
Gbettner's Avatar
Gbettner
Default 2002-2012 3.7 differences?
Hi everyone,
I have a 2010 dodge ram 1500 2wd 3.7 V6 with a motor that blew out the bottom end. It's junk. Will an older 3.7 ( say a 2002 for example) work? Engine compatibility seems to be 2009-2012 only. Is this because of accessories , sensors, bolt on parts that can be changed around or is it block/internal differences?
Thanks for any help, I haven't found a solid answer yet
Gary
Old Aug 25, 2023 | 07:23 PM
Dakotaqueen07's Avatar
Dakotaqueen07
Default Difference
The compression ratio is different . Along with many other things. I'd suggest a 2006 or above to find the most compatible engine.
