Ambient temperature sensor
Old Aug 24, 2023 | 02:58 PM
JMcruising's Avatar
JMcruising
Default Ambient temperature sensor
I need to replace the ambient temp sensor on my 2017 Laramie. It's reading 60 degrees outside when its 85 and my engine light is on. Already did diagnostic. Everything I've researched says it should be between the grill and radiator. I removed the grill and cannot locate it anywhere. Can somebody point me in the right direction please. A picture even better! Thanks
Old Aug 25, 2023 | 08:08 AM
From what I've read, it's in the drivers side view mirror arm. Look for a little door or latch.
Old Aug 25, 2023 | 04:00 PM
JMcruising's Avatar
JMcruising
Thank you jkeaton! I found it easily to replace. Literally takes two minutes. Looks like I need to find a new repair shop because they wanted to charge me $313 to replace this $15 part. Disappointed in them.
Old Aug 25, 2023 | 06:22 PM
Or maybe you are in the wrong line of work. If you could make over 300 bucks in two minutes, I bet you would do that all day.
Old Aug 25, 2023 | 06:32 PM
JMcruising's Avatar
JMcruising
Funny thing is that my line of work is sales. Long term valuable relationships are built on customer service, trust and credibility that then leads to way more money in the long run. I take 4 of my family's cars to this shop for regular service and major service. If he would have said to me that this is a simple fix and charge me $100 for diagnostic, part and replace I would have been happy. He may have not made an extra $200 in two minutes but he also wouldn't have lost me as a customer and several thousands of dollars over the next couple years. It makes me think what else he has overcharged me for over the last couple years. Sad for a family owned local business. Thanks again for your help!
Old Aug 25, 2023 | 10:35 PM
Maybe have a chat with him, and point that out to him..... It is rather hard to find a shop you can actually trust. Though, if this guy wants to gouge you that hard for a 2 minute job...... Good chance you SHOULDN'T trust him....
Old Aug 26, 2023 | 11:59 AM
SHO Rod's Avatar
SHO Rod
Did the new ambient temp sensor fix the issue that was causing the check engine light to come on? I'd be a bit surprised if an ambient temp sensor causes a check engine light. Maybe the shop you've been going to was also estimating to fix a secondary issue that maybe was indicated by the diagnostic code.
-Rod
Old Aug 28, 2023 | 09:34 AM
JMcruising's Avatar
JMcruising
Yes Sir, I do plan on chatting with him.
Old Aug 28, 2023 | 09:35 AM
JMcruising's Avatar
JMcruising
Part arrives tomorrow and will let you know what happens. That's all his paperwork said though as I paid the $78 diagnostic. Just replace sensor.
