yaw rate sensor loacatio
Old Aug 24, 2023 | 04:31 PM
goose32's Avatar
goose32
Default yaw rate sensor loacatio
Hey yall, ive recently come across information on how to shut down your traction control system without having to pull fuses and such. It involves located the yaw rate sensor or traction control sensor and install an on/off switch into the ground wire of that sensor. It prevents that sensor from working but keeps yours abs alive and then you get the convenience of actually fully turning off your traction control system with the flick of a switch, and not having to pull fuses. However i own a 14 ram 1500 with front row bench seats. When i pulled my seats out, all i could find was a big square computer model that looks to control air bags in the case of roll overs and such, and that yaw rate sensor is no where to be found. Is that yaw rate sensor incorporated into that big computer box sensor or is located somewhere else on my truck like under the hood. Trim modle is an outdoorsman-bighorn 5.7 hemi crew cab. Any help in the location of finding that sensor would be appreciated cuz google is a dead end for help.
picture is of that control model located under middle bench seat
Old Aug 25, 2023 | 06:57 AM
Just one thread please.
