Loud noises when driving, but not always
Old Dec 7, 2023 | 05:32 AM
Vika070824+'s Avatar
Vika070824+
Default Loud noises when driving, but not always
I would like to ask for help if anyone can identify the loud, cracking noises coming from the front axle. The front wheel bearing has no play, the upper and lower wishbones are also tight, the bushings are OK. Stabilizer OK, stabilizer support too.
New front brake pads, brake disc in order. Rear parking brake also checked. Actually the noise can only come from the C/V Axle. Has anyone ever heard a cracking noise like that?
Thank you very much for your help!
File Type: mov
Old Dec 7, 2023 | 02:28 PM
That's going to be either one of the outer CV joints on the axles, or, the CV joint on the front driveshaft.
