ABS Light issue....
Old May 25, 2025 | 11:32 AM
theuscfan04's Avatar
theuscfan04
Default ABS Light issue....
So my in-laws just bought a 2016 bighorn 1500 yesterday with 108k and discovered the abs light is coming off/on. After a little research it seems the speed sensor fixes this issue?
Can anyone chime in for some help on this?
Old May 25, 2025 | 11:39 AM
2 or 4 wheel ABS? Really need to read the codes to see what it is whining about.
Old May 25, 2025 | 12:13 PM
theuscfan04
4 wheel abs
Old May 25, 2025 | 12:42 PM
Yeah, then you REALLY need to get the codes read. Your local parts store may be able to plug in, and see what's up..... But, not all of them will do ABS or SRS systems.
Old May 27, 2025 | 07:03 PM
SHO Rod's Avatar
SHO Rod
Agreed, there is more than one "speed sensor" associated with the ABS system, along with several other sensors (yaw, steering angle, etc.). Also, even if a code pops up for a wheel speed sensor, that doesn't necessarily mean the sensor is the issue. It could be a corroded connection, a damaged wire, metal shavings on the sensor, or a cracked or damaged tone ring. Diagnostic codes are just that, for diagnostics. Rarely is there a code that says "no kidding, this is the faulty part."
-Rod
Old Jun 2, 2025 | 12:57 PM
theuscfan04
so the code is c2200-49 (ABS module) the readings on the 4 sensors were all the same except the drivers side front, which was a little bit higher than the other 3.
Old Jun 2, 2025 | 03:02 PM
Bad ABS module. Need to replace it.
Old Jun 2, 2025 | 03:04 PM
SHO Rod's Avatar
SHO Rod
That code would suggest a fault internal to the module rather than a wheel speed sensor issue (are all 4 tires inflated properly?). This may actually be one of those cases where the code is pretty indicative of a particular part failure....
-Rod
