P0440 and P0456 faults after fuel level sensor replacement
Old Jun 1, 2025 | 12:27 AM
TravisC's Avatar
TravisC
Default P0440 and P0456 faults after fuel level sensor replacement
I have a 2012 Dodge ram Big Horn with the 5.7 engine and the large fuel tank. A week ago I dropped the fuel tank to replace the fuel pump and fuel level sensor which went well. This week I threw codes of p0440 and p0456 for EVAP system and evap small leak. I cleared the codes and they came back 2 days later. I've inspected the EVAP lines and everything looks good. Before I start replacing the sensors or dropping the tank again, any suggestions on where to look first? Is this possibly throwing codes temporarily because I disconnected the lines when I drop the tank and it will go away on its own? And for those wondering, yes, the gas cap is screwed on tight.
Old Jun 1, 2025 | 08:41 AM
Smoke test the evap system.... Maybe there is a hose that just needs tightened.
