ABS Control Module
Old Sep 15, 2025 | 12:13 PM
jacmates's Avatar
jacmates
Question ABS Control Module
Connected scan tool to my 2015 Dodge Ram Express with a 5.7. I have a ABS/Traction Control/Brake Lights on. The code I got was C2200-049. I looked it up and it says that my ABS Control Module may be bad. I looked up one and they are expense. Does anyone know where I could find one that is not very expense? Thanks.
Old Sep 15, 2025 | 12:24 PM
Do a google search on the part number. Likely can find one that is refurbished for relatively cheap. (as these things go......)
Old Sep 22, 2025 | 10:30 AM
jacmates's Avatar
jacmates
Once you replace the ABS Control Module, do you have to take your truck to the dealership to get the code cleared?
Old Sep 22, 2025 | 02:09 PM
SHO Rod's Avatar
SHO Rod
I'm not positive on the 2015 Ram, but it's not uncommon for vehicles with a CAN bus to need to have the ABS Control Module coded to the vehicle. Sometimes this is as simple (assuming you have a scan tool or AlfaOBD) assigning the VIN to the ABS control module, but it can also require knowing the assembly line settings specific to your vehicle's options and coding those settings as well.
-Rod
