Question on air suspension height
Old Jan 23, 2026 | 05:49 PM
Machomur's Avatar
Machomur
Default Question on air suspension height
I have a 17 Rebel with air suspension. I drive with it in aero position. Can I drive with it lowered all the way? I feel I would get better mileage in a stiff headwind.
Old Jan 23, 2026 | 06:09 PM
Theoretically, "Aero" gives you the least wind resistance..... I would expect that if that air bags are only in the rear, lowering it all the way would have the rear lower than the front, and you would get higher wind resistance that way. Would it make a noticeable difference? Doubt it.
Old Jan 23, 2026 | 07:00 PM
Machomur's Avatar
Machomur
Airbags are in the front also and the truck stay level when it raises and lowers. I also wonder how much difference it makes in reality but I’m willing to find out if it’s safe to drive it in the lowest position. A four hour drive into a headwind gobbles up some gas.
Old Jan 23, 2026 | 08:36 PM
A four hour drive with a tailwind gobbles up some gas.
If all the way down doesn't have the suspension sitting on the bump stops, I would expect it'd be fine for an unloaded truck.....
Old Jan 24, 2026 | 11:58 PM
SHO Rod's Avatar
SHO Rod
The Entry/Exit mode is essentially sitting on the bump stops is pretty uncomfortable at any speed above just a few miles per hour. I feel like you'd be likely to break something or damage tires if you were to drive highway speeds on the bump stops.
-Rod
Old Jan 25, 2026 | 08:51 AM
Machomur's Avatar
Machomur
-Rod
thank you sir
Old Jan 25, 2026 | 09:28 AM
Machomur's Avatar
Machomur
-Rod
thank you sir
