crewcab subs
Old Jan 9, 2010 | 03:12 AM
kidkaos520's Avatar
kidkaos520
Default crewcab subs
Hello all this is my first post and I am new to this whole forum thing. I just bought a 09 ram crewcab and want to put a pair of 12's under the back seat but not sure where I should get them from or if I should just have someone build them. Any information that I can get would be appreciated i.e. specs websites pics, or instructions. Thanks
Old Jan 9, 2010 | 03:46 AM
devile's Avatar
devile
If you want a prebuilt box, anything built for a quad cab from 03 up will work... MTX has them...
Old Jan 9, 2010 | 01:02 PM
kidkaos520's Avatar
kidkaos520
I was just making sure because I found a 08 crew cab box but it seemed like it didnt fit in their perfectly. Just was not completly sure if I should get that one or spend a couple extra bucks to get an 09 box. By the way has anyone purchased anything from brighstarcaraudio.com
Old Jan 9, 2010 | 02:52 PM
daviddto's Avatar
daviddto
just my 2 cents, but if you want to use 2 12's I would do a seat lift and build a fiberglass box the uses all airspace available.I did that in my 4th gen and sounds great
Old Jan 9, 2010 | 03:20 PM
kidkaos520's Avatar
kidkaos520
I was thinking that also.....someone also told me that rather than risk the 12's with the limited space I should get two 10's (cvt). Also should I dynamat the doors and rear?
Old Jan 9, 2010 | 03:31 PM
daviddto's Avatar
daviddto
Dynamat will make the stereo sound better and help with the rattle. Not to mention kill some road noise
Old Jan 9, 2010 | 03:36 PM
kidkaos520's Avatar
kidkaos520
Do you know how much dynamat would be needed
Old Jan 9, 2010 | 03:56 PM
daviddto's Avatar
daviddto
No I dont but you can use some stuff called fat mat. You can find it on e bay. Just a guess, 50sf should do the roof, doors, back wall and part of the floor.
Old Jan 9, 2010 | 04:11 PM
daviddto's Avatar
daviddto
Here is a pic of my first experience using fiberglass and resin. I used the carpet as a mold and then used 3/4 inch mdf to finish the top of the box. I also have a 1 1/4 seat lift. the seat lift is made from square tubing I bought from home depot.
Old Jan 10, 2010 | 03:23 AM
Rizam's Avatar
Rizam
So my foxbox from my 07 will work in my new 09?
