5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
2019 Ram 2500 Rear Upper Control Arm Torque Spec
Old Feb 27, 2022 | 05:41 PM
Piedpiper's Avatar
Piedpiper
Default 2019 Ram 2500 Rear Upper Control Arm Torque Spec
I tried searching for this but didn't find anything. I'm not a mechanic so I will describe what I'm doing as best I can. Basically, I need to know what to torque the stud/bolt to that connects the upper control arm to the frame in the rear of the truck.
I'm installing wheel-to-wheel running boards on my new-to-me 2019 Ram 2500 6.4L crew cab and I had to loosen the stud (bolt) that connects the rear upper control arm to the frame (see pic) so that I could slide a bracket underneath the head of the bolt. The opposite end of this control arm connects to the axle. The bolt I'm referring to is located just in front of the rear wheel and uses a shackle mount to connect the control arm to the frame. I need to know what torque to re-tighten that bolt to.
Also - I think I have the correct torques for the A, B and C pillar cab mount bolts but if someone could confirm, I would much appreciate it. I read the the A and B pillar cab mount bolts to 80ft lbs and the C pillar to 85 foot lbs. Is that correct?
and yes, I'm ordering a service manual. Guess I got a little excited and got ahead of myself here.
Old Feb 27, 2022 | 06:58 PM
Piedpiper's Avatar
Piedpiper
Correction - I should have said the rear LOWER control arm NOT rear UPPER control arm.
I think the bolt in question is called a hex flange headbolt
Old Feb 28, 2022 | 12:45 PM
Dealership service department should be able to tell you. Worst case, go in and see 'em, and ask to see the body manual for your truck. (where ever the suspension section is. )
Old Feb 28, 2022 | 03:12 PM
Piedpiper's Avatar
Piedpiper
ok, thanks.
