5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
New here
Old Jun 18, 2023 | 05:22 PM
LikeWater's Avatar
LikeWater
Default New here
Hello, I own a 2020 ram 1500 classic tradesman and I was trying to troubleshoot a leak under the dashboard glove compartment area. Seems to be excess condensation causing a drip into underneath the carpet. I already put vacuum to the drain tube and also hit it with compress air.
any help would be much appreciated
Old Jun 18, 2023 | 08:56 PM
Does the drain tube stick straight out of the bulkhead in the engine compartment? If it does, put a 90* elbow on it. That solves it for the second gens at least.
Old Jun 18, 2023 | 10:59 PM
LikeWater's Avatar
LikeWater
Yes it does stick straight out. I put a shop vac to that to see if maybe it was a clogged drainage tube issue but that didn't seem to be the case. I went to look for heater hose 90° elbow so I could clamp it on. But couldn't find any a home depot I will need to continue to look. Thanks for the help. I put the 90°(heater hose w/clamp) elbow on the ac drain tube but the ac condensation leak is still occurring inside at the same previous area in the picture.
Old Jun 25, 2023 | 11:35 AM
racerxv6's Avatar
racerxv6
Is that plastic tube cracked. it almost looks like there is a crack across the bottom?
Old Jul 22, 2023 | 05:58 PM
William Scott's Avatar
William Scott
what did you do about the crack ?
