5th Gen Ram Tech 2019+ Ram Trucks: This section is for TECHNICAL discussions only, that involve the 2019 Ram 1500.. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Engine identification help
Old Jan 14, 2025 | 10:03 AM
Brn2fly's Avatar
Brn2fly
Angry Engine identification help
I have a 2021 ram 1500 classic with a 5.7 Hemi, I purchased it used at a dealership as a certified vehicle and I recently was under the vehicle and noticed the engine looked older then it should, when I looked at the numbers on the engine it showed a number that doesn't pull up online or in the system at parts from dealerships. The only thing i got from one dealer was it looks like a 2017 code. Please help me to identify this engine.
the number is 68299711EA.
Thank you
Engine part number
Engine part number
The head part number
Old Jan 14, 2025 | 06:42 PM
5.7 Hemi, MDS and VVT theoretically. Looks like the engine has various iterations, as I see a good collection of 'revisions number" (last two letters of the part number) online. Looks like they used 'em from around 2013 on.
Old Jan 21, 2025 | 02:01 PM
Brn2fly's Avatar
Brn2fly
I need help the used truck at the dealer says this is the factory motor
Is this the original engine for this vehicle
SN#TNXE6342011860
part#p68299711ea
2021 ram 1500 slt vin#1C6RR6TT4MS517583
Old Jan 21, 2025 | 02:05 PM
Well, the part number is correct for size, and year, from what the truck came with from the factory, but, is it THE engine that was installed at the factory? No way to know. Have to chat with dodge about that one.
Old Jan 21, 2025 | 02:34 PM
dodgetruck2's Avatar
dodgetruck2
As a certified vehicle I would assume you got a car fax, and at 3 years of age I would assume an engine if replaced, was done under warranty., what's the mileage? That information would be published on a Carfax report wouldn't it? At the very least mopar warranty service would have record of it.
How do you consider visibly looked older? Rust? Corrosion?
A better help would be finding a date of manufacture stamp, almost every part on the engine will be stamped in some way will a date clock or Julian date code for manufacturing, of course parts are stored in house for months or sometimes years before use. however finding a 2017 date stamp would be fairly unlikely if it is indeed a 21 motor
