Rear End ID for 5500s
Please help me identify the rear-ends for my two 5500s. One is 2 wheel drive and has the VIN 3C7WRMCL5NG196052 ; the other is 4 wheel drive and the VIN is 3C7WRNBL3MG599100
Thanks,
Bill
Thanks,
Bill
The one with the pictured VIN is a 2022, the other is a 2021.
Thanks. The dealer says the 4X4 5500 has a 4.44 ratio and the 2x4 5500 has a 4.89. The 4.44 is dying and I've pulled the engine for the 2x4 truck because a bad lifter broke the push rods in the 6th cylinder and will be a while before I can put it back together. Question is if I can replace the 4.44 with the 4.89?
Trending Topics
Sure, the speedo won't be right, and the ABS *may* whine about it..... but, do NOT use 4x4 with mismatched gear ratios. That gets expensive right quick.
Whats the problem with the original rear? If it's just bearings, those are easy enough to replace.
Got you on the 4x4, guess I could disconnect the transfer case but will get a new 4.44 rear end since I can't afford the down time to rebuild it in case we run into a snag. Not sure what's going out in it except it's whining louder and louder by the week. Any recommendations for sourcing a rebuilt differential.
Ouch..... If there is a truck shop in the area, I would be more tempted to take it to them, tell 'em to fix it, then write 'em a check...... Probably only be down for a day or three, and it'll be a LOT cheaper that replacing the entire rear.
