FS2500 oil by-pass system
FS2500 Oil by-pass filter
This is just about new with only 500 miles of use. This kit has the bracket to mount on a Dodge Ram Cummins ( to the block right in front of the air intake horn ). I had it set up to return to the valve cover. On a Dodge all you will need to use whats here is a Amsoil valve cover cap ( part # BMK-11 ) It comes with everything you see in the pictured which includes:
FS2500 by-pass filter
brand new filter w/gasket
anodized fittings already installed
2- 6AN stainless steel lines
anodized fitting for connecting to oil port on block
engine mounting bracket
oil test plug
I have $675.00 into this kit with the new filter, AN fittings and SS lines.
Im asking $500 shipped in the CONUS. for everything you see in the pics.
$425 for just the filter without the fitting and SS lines. It will have the regular rubber lines included
Paypal is preferred
![](http://i237.photobucket.com/albums/ff165/tritont/FS2500.jpg)
![](http://i237.photobucket.com/albums/ff165/tritont/truck561.jpg)
![](http://i237.photobucket.com/albums/ff165/tritont/truck571.jpg)
